B&S EX675 weird governor plate
Njitnoc
Hi all,
I recently bought a second hand mower equipped with an EX675 engine, model number 126T02-6307-H1. It was not running great so I decided to check the mower and I discoverd this governor plate. Has anyone seen this type before? It is not in the parts manual and I can not seem to find it on the web. I have removed the throttle cable because it was a piece of rust. Any help is appreciated.
Scrubcadet10
Moderator
Staff member
If i remember correctly,the governor spring (in blue) should be hook into that hole circled in red, and be anchored to the governor link rod in the loop of the rod.
Variable speed throttle with automatic choke. Item 222G from this diagram
And item 1386 from this diagram
Along with the spring connection in @Scrubcadet10 post
Njitnoc
Thanks for the fast reply. I just discovered that the red circled hole has been bent, it should be placed more to the right so it is positioned further away from the carb and can create tension in the spring. That also explains why it was poorly running, I hope. I will check in the upcoming days, thanks!
