Greetings: I've got a Toro pushmower (Recycler) - 4 or 5 years old - B&S 124T02-0203-B1 - and after I run it (starts normally) a while and shut it off it will not start until it cools down some - my research shows it's probably a bad exhaust valve - is there anything else I should check before I start trying to replace the &*%$# exhaust valve? thanks in advance.....
