B&S Commercial series Vertical twin. Need torque values for crank and engine mounts
rossnruthie
  • / B&S Commercial series Vertical twin. Need torque values for crank and engine mounts
Hey guys, I just got a new Briggs commercial series 27HP engine for my zero turn and I'm ready to install it. However, I cannot for the life of me find any torque values for the 4 self threading screws that mount the engine to the chassis or the single crank bolt that holds the clutch on. Can someone help me out?
Thanks!
Re: B&S Commercial series Vertical twin. Need torque values for crank and engine mou
There isnt one.
Going into alloy you are looking at no more than 30 ft lbs however it is a self tapping bolt so you will have to do it up first to cut the thread then undo it to tension it.
Generally done up with an impact wrench on low setting till they bottom out.
Check for tightness after the first mow, two grunts with a 10" wrench is usually fine.
rossnruthie
Sounds good thanks!
