mysguidednlv
I've been battling an idle issue with a B&S 675 Series 190cc engine... its the model with the "auto-choke" (which is a royal pain:thumbdown
. When I start the mower, it usually starts within 5 pulls, the engine revs up to well over the 3300 which is the standard idle speed (my best guess would be somewhere in the low to mid 4k range). The engine temp jumps up pretty quickly activating the auto-choke "knob" which in turn closes the throttle plate. Within 10 seconds of this, the RPMs gradually drop down to the point where it stalls. I've tried adjusting the governor plate and can't seem to find a point where it will stay idling.
Before it started doing this, it would simply run at high idle continuously (roughly high 3ks), then yesterday, this started happening.
I've pulled and cleaned the carb, checked the plug (it's good), tried adjusting the governor plate, checked and confirmed the auto-choke is working... any other suggestions on what may be causing this issue? My next thought is to replace the governor and throttle-plate arm springs, but the mower has only been used for ~3 years and seems too new for springs to be a problem. Any other ideas are greatly appreciated!
