Just gap it with a typical thin business card and the gap will be ideal for the coil to produce fire at the plug.
Yup, have been using business card and then verifying with feeler gauge.Just gap it with a typical thin business card and the gap will be ideal for the coil to produce fire at the plug.
I don't want the mower to beat me - I need to know what the problem is or I will forever feel bad that I have failed! At least I was able to return one of the coils. But I do appreciate your suggestion.Don’t throw any more parts at it (two ignition coils so far). You can buy a good used push mower for around $100 if all else fails…
I have removed the big nut that fastens the flywheel and the flywheel key looks good. But I have not removed the flywheel.I’m with the team to drain bowl and tank.
Definitely possible to have a blockage, but after everything is drained a shot of starter fluid should get it to fire.
Have you checked the flywheel key?
I will certainly drain and clean the tank befoe refilling with fresh gas . Thanks!Did you drain the fuel tank? You could have crud in the tank. Auto Doc's and slomo both mentioned this.
I am planning to drain gas tank and float bowl and put in fresh gas and see what happens. The gas I used was very new but I suppose it could have been bad.
I did take the carb off and shot starter fluid directly into intake without success. But one contributor questioned the type of starter fluid I was using. The 2 times (out of many) that I did get it to fire, were with the carb off and the direct shot to the intake method. But it only worked twice out of many attempts.
