B&S 17.5hp on Craftsman T110 Extreme white smoke at startup
ECOB00ST
  • / B&S 17.5hp on Craftsman T110 Extreme white smoke at startup
B&S 17.5hp on Craftsman T110 Extreme white smoke at startup. Oil is fresh and at top of hash marks on dipstick. Blue/white smoke pours out of the muffler for the first 5-7 mins of warm up then clears up. Otherwise runs fine. What can be causing this? It's only about 1.5 years old with normal use.
Scrubcadet10
Moderator
Staff member
If its the engine i think it is, most likely it is a blown head gasket between the push rod chambers and the cylinder. a quick check you can do is let it run to operating temperature, shut it down, and remove the dipstick, if you see whisps of smoke coming out of the tube, most likely the head gasket is blown.
Please post the model, type and code of the engine,
ECOB00ST
Ok. Thank you. I'll look that up and post it later today. Would a blown head gasket stop smoking when the engine warms up?
ECOB00ST
31R9070062G1 is on the sticker on the engine as the engine model number but I can’t find it in the B&S website. Trying to find the proper gasket.
Hammermechanicman
Yes, a slightly blown head gasket can cause it to smoke on startup then clear up and run good. I just changed one a few months ago where it would puff one big puff of blue white smoke on startup and then run fine.
ECOB00ST
Yea, mine clouds up the neighborhood for 5-7 min with thick bluish/white smoke, then runs fine with no smoke when warmed up.
Scrubcadet10
Moderator
Staff member
