Sounds like your not getting fuel. Check following things
Gas Cap (should have a bleed value to stop it from making a vaccum.)
Fuel Filter
Fuel pump
Float valve
Main jet
One of the above is not letting fuel through. You can remove the gas line from the carb, put the end in a container, turn the engine over with the starter and see if fuel is comming out the line. If it is you'll need to pull the carb apart and rebuild it. You probably could just clean it, but while you have it apart, and claen, you might as well rebuild it IMHO......
