AND ...... when ya get a few extra "sheckles" put aside, ... think about gettin a "Speed-Feed" head .. :thumbsup:
I keep coming back to the Echo Cross-Fire string myself. I like how it cuts and it's fairly tough/durable. I run the 095 in my loop handle trimmers for my regular mowing route and 105 in my Sthil bike handlebar trimmer that I use for less regular trimming duties.Yep, cheap string will weld more often. I use Echo Cross-Fire string. Never had a weld issue.
Yes agree about Revved up & then bump to advance string.
And using line that is too thick for the size of the engine will cause the line to weld together a lot more .
And it is actually a friction weld, that is just how easily plastic can weld.
