Ariens Zero Turn Ikon XD 52 - dead!
JP98
Hello Friends-
I am in need of help!! My zero turn Ariens Ikon XD 52 won't start! It was working fine last weekend when I cut my lawn. I turn the key and it does nothing. I tried jump starting it and still does nothing. It doesn't even make a clicking sound. I thought it might the ignition switch so I bought one, replaced it and still nothing. I jumped the starter solenoid and still no response! It did not turn the starter. The handbrake is up, which is required to start it. Any suggestions are surely appreciated
I would start with checking the battery and/or charging it. If it didn't crank by jumping the starter solenoid I would be leaning toward dead battery.
MParr
Dead battery.
PTO switch is on.
Faulty safety switch.
Blown fuse.
Bad ground.
JP98
I have One of those portable jump starters. I tried it and it didn't crank. But I guess I didn't leave it on there long enough. I'm going to charge the battery all day tomorrow. Thanks for your suggestion.
JP98
Dead battery.
PTO switch is on.
Blown fuse.
Bad ground.
Yeah I will try to charge the battery tomorrow.
PTO switch is not on. I made sure.
Fuse is not blown. I checked
I don't think it's a bad ground but I will triple check it.
Could be a faulty safety switch. Is there any way too bypass it just to test?
MParr
Check the wiring diagrams. You will need the model number and serial number to find them.
JP98
Well, it turned out to be the damn battery. I charged it all day and it started. I was able to cut the grass but when I shut it down and tried to restart it, it barely turned like it was dying so I took it to O'Reilly Auto Parts to get it tested. Sure enough, it's a bad battery. This battery is barely 13 months old. What a piece of crap! O'Reilly only warranties them for 3 months.
MParr
To save yourself from complaining about the next battery failure in 13 months, go to Walmart and buy you a Battery Tender Jr. Keep it hooked up whenever you aren't mowing.
My original equipment battery is going on 4 years of age. It stays hooked up whenever I'm not mowing.
JP98
I'll do that. Thanks.
