Are tech manuals available somewhere?
Maylar
Hi folks -
New guy from Connecticut checking in.
I need to give my snow blower some attention before the winter sets in here in New England. It's a 15 yr old Craftsman with a Techumseh series HSSK50 engine. I've not been able to find any detailed information regarding setting up the motor, particularly the carb linkages and governor adjustments. Before I start posting specific questions regarding symptoms, I'd like to be sure that the machine is set up to factory specs. Looking to find out which holes the springs and linkages should be connected to, and what the high speed RPM should be, etc.
Are there tech manuals available somewhere that would describe these things?
Thanks.
Dave from CT
Maylar
Thanks very much. A lot to look through there.
jp1961
Intertec published a manual called Small Air-Cooled Engines - Service Manual, that does cover Tecumseh engines. Not sure if that particular engine is covered, as Tecumseh manufactured a TON of different engines
