ebontrager93
- Jul 16, 2016
- 1
it's a small Briggs and Stratton engine on a Husquavarna mower. The engine starts and then it just quits right away. I've replaced the air filter and the spark plug. The oil is full. I disassembled and cleaned the carburetor. I've sharpened and balanced the blade. I've checked the flywheel key. Now I don't what to do next. Replace the ignition coil? Adjust the valve?
