- Nov 29, 2014
- 24,995
I did not turn it up on its side, I did sit it up on the back end initially.
Whoever replaced those belts torqued those nuts/bolts way too much. And they could have just moved that bar slightly by a 1/4" so you could get a ratchet on that trans pulley
Being under the battery it gets battery fume and also water drips down the battery box and fight on to the pulley.
Then you have the splined shaft, the pulley and the nut. add some moisture and your are at rust central.
If you overtighten the pulley bolt the shaft breaks.
I found that out the expensive way when I hit it with the rattle gun in place of the tension wrench..
