Alternator not charging battery
If it has a DCV output of 13.6 it will go to the battery for charging. I’m glad to see that you took the time to read the manual I posted and understand the charging system the charging system for your unit. I hope you understand why safety systems should not be disabled.
Well most of the wireing was mangled from the previous owner so i just redid it all but ill hook it to the battery and see it it charges
