curtis deppe
how do i adjust the valve clearance on a kohler command13 it says it is a hydraulic valve the engine is weak when the mower is engaged
Why do you think it is the valves?
You should never have to touch them. Unless something breaks.
I have seen the Command rockers back off until they no longer open the valves far enough and makes it difficult to start and causing low power. Wear on the rocker arm tips and valve tips can also create a gap.
