air filter
dubba
Is it ok to use an air filter which was very wet with gas & stablizier but is now dry?
Gas residue tends to clog the pores in the element rendering it useless because of the air flow restriction. I have seen water do the same thing on certain air filters.
Since you didn't specify which type of air filter, paper or foam, I will add that if it is a foam filter you can usually wash them out with dish soap until clean, wring out excess water, let dry, add a little engine oil and squeeze out the excess oil by hand.
If it is a paper filter, just get a new one.
To everyone who answered my question concerning a air filter, thank you very much. Dubba,PA
