You have to start somewhere, have your battery checked.  You ask more help, but then instead of following our suggestions, you question our answers.  As reynoldston said we are not there to see your unit.  You haven't even posted any engine or unit model and serial numbers.  Kohler makes many different types of 15 HP engines  we don't even know the type of unit you have, for all I know it is a cement mixer.  If the battery is good, you are going to be looking for a dead short draining the battery.  That short could be anywhere.  It may be a short between the charging circuit and the run circuit, which will drain the battery and kill the engine.  This is not as simple as black and white.  That being said, I am bowing out of this one, as you don't like my answers anyway.  Bye.
