Adjustment
Larry D
I have a Tec 10 HP which has 3 or 4 pickups inder the flywheel along with the points. How do I set them?
This is a new one on me. Seeing it has points it has to be a older engine. Just what do you mean by 3 or 4 pickups? Maybe you have the flywheel off if you see the points and condenser? maybe wire connections? Just what are you setting the points? Yes I agree maybe a engine model would help here other then just Tec 10 HP.
