- Nov 29, 2014
- 24,995
You get a pump/motor kit that is complete apart from the axel seals & oil.
It is about 1/2 to 2/3 the discount price of a new tranny depending upon where you get them from.
While they are simple in construction they are high precision machining and high precision cost a lot of money.
I have access to polishing wheels from a previous life as a metallurgist so I can polish the surfaces down to 2000 grit with wet & dry then pop them on the plate and take them down to 4 micron.
Sometimes this works, and sometimes it dosent , it all depends where the wear is.
If it is just the valve chest & manifold plate then they can be lapped if the wear grooves are not too deep but if the wear is in the cylinders then it is scrap metal.
