173abn
- May 7, 2010
- 38
- 869
hope somebody can help me ,my 928d is designed so that you can get off the mower while running if you shut off the pto and put the steering arms in neutral.all worked fine until the other day while mowing and I stopped to pick up a limb,putting the mower in neutral I heard a grinding noise back by the starter.I looked back and saw sparking every time I put the steering arms in neutral and thinking I had a short I looked closer and saw the starter bendix engaging every time I put the arms in neutral.whats really strange is I can start it up mow etc. and everything works great but if I put it in neutral it grinds.the starter itself don't seem to be engerized just the gear that moves the flywheel.I looked at the left and right steering switches and checked for shorts in the wire but came up empty.it's got me stumped and I'm hopeing someone with a whole lot more knowledge about these things can help. thanks russ
