917272960 Craftsman rider New ground drive belt won't tighten
according to Searspartsdirect.com The manufacturer no longer makes this part, and there's no substitute part
but the OEM original number is Part #140218
The craftsman belts are usually an odd size and need to be exact same size as the discontinued OEM belt.
You should need a 84.5” X 1/2” belt.
If it falls off real easy then the belt keeper might need some tweaking with a 4lb hammer.
It should sit no more than 1/4" away from the pulley
The belt number Srubby came up with codes out as a Gates 6811BR
https://www.gates.com/us/en/ymm/search/part/details?part-number=6811BR
As you see that is 84.25"
All of the after market parts suppliers have a chart of OEM spec belts by length on their web catalogues.
stens list
265-974 an 84.25" drive belt , Bolens 1756725
265-275 an 84.5" drive belt MTD 954-04252
