914H would like to adjaust Hydro balance.
Hitechluddite
Put all new belts on it and a new generic EBay carb. it runs good and the plug looks good now. I might adjust the governor linkage a little in the near future but want to run it some more because it was sitting for some time before I bought it. The mower creeps slightly while in the center neutral position. It's not a big deal but if it is a simple alignment I'd like to make it right. I was able to go to Simplicity's site and download a parts and owners manual but pages 21-30 are missing and that is where the alignment instructions are any help is much appreciated!
JoeM(GA)
I have a PDF of the 900 series service manual you're welcome to, if wanted, shoot me your email
joe
johnorlandi
I believe all the tractors are the same I have tried to attach a Sovereign manual but it is large I have tried to attached a screen shot and it would not allow me to so if you want the manual give me you email address
johno778@cox.net and I will send to you can also add the 918H to it
johnorlandi
I was able to upload in a pdf format see if this helps
  • neutral adjustment.pdf
