rich_kildow
I just picked up my 7116H model 1691382 and would like to add a hydro or electric lift at some point...it is manual now.
Is the hydraulic lift cylinder powered off the main hydro pump that powers the drive? I assume there is another set of ports on the hydro pump that are blocked on models with the manual lift.
It seems to me that all I should need (beyond hoses and bolts, which can be fabbed) is for hydro is the valve assembly, rear support for the cylinder, cylinder, and control lever. It uses the existing cable, front rocker shaft. Is there anything that I am missing?
The electric would simply require the wiring, actuator, and a rear bracket. Does anybody have any idea the lift rating or stroke length on the electric lifts that would go with this model?
