7000 Series Engine Oil Pressure
funflyer
Just in case you were wondering what the operating oil pressure is on one of these engines, here you go. Engine has 6.5 hours and had it's required 5 hour oil/filter change so it should be a good baseline for testing different weights of oil and aftermarket filters.. Oil is Kohler 10w-30 and filter is Kohler 12-050-01S. Ambient temp was 83 degrees.
As you can see, the pressure drop from cold to hot is about 2 PSI.
