I have an inherited Simplicity 6200 series lawn tractor. I was recently doing some routine maintenance (oil change, spark plug, carb clean) and in pulling off the carb the mechanical linkages (2 rods) are disconnected. I should have taken a picture of the carb and throttle before but I didn't. Now need help to get these rods and the carb adjusted.
I can get the mower to start in low throttle position but it revs high in mid throttle stroke so I don't have something adjusted right.
Does anyone have any tips (and pictures!) of how the throttle should be linked up to the carb?
Engine is Briggs model 253707
