I have a 60” Husqvarna zero turn that I use to cut two local athletic fields. The grass is Bermuda that we keep at 1.5”. i took my mower in for service and new blades to our local dealer. They put blades on it for a 54” mower, so the first time I cut there was a 1” strip of grass left between each set of blades. Long story short, we got some blades from another local store and put them on. Now when I cut the two outside blades cut lower than the center blade. I can’t tell if the center is high or the two outer blades are low.
The mower cut beautifully before changing any blades.
any thoughts or suggestions.
