I have a fairly unused Craftsman 6.5 HP Briggs and Stratton push mower that hit a rock, then ran extremely rough, smoking and without much power for about 10 minutes.  Immediately afterwards, it would barely start and only run briefly but with a lot of clanging and with some smoke.  It is model that has a has an operator presence bar on the handle that, when released, stops the engine and puts a mechanical brake on the flywheel, if that helps at all.
Some research pointed to a shear pin as a probable problem. So . . . I took it apart and sure enough, it was shorn apart and the flywheel was rotated by the width of the pin at the spindle. I replaced the pin and installed it uneventfully.
Proud of myself for fixing it and getting it back together, I primed it and pulled the cord. It always started easily on the first pull. However, to my disappointment, it smoked and bucked and ran roughly with a noise like someone banging a steel pot - clang - clang - clang and then quit in ten seconds. Subsequent pulls never got much of a kick out of it with it almost sounding like it wants to start, but nothing but a quieter sound - about 5 clangs per pull.
Inspection of the underside - the blade has a ding from the rock, but feels pretty firmly attached and is definitely not hitting anything. Not sure what a bent shaft would feel like, but the blade seems to turn without a wobble. Now that I think about it, should have pulled the spark plug to make it turn easily to help me diagnose, but I did not.
Perhaps the shear pin slipped. But I doubt it. It did seem to go down a bit below the level of the flywheel when I inserted it.
What's the next step?
Thank you for reading!
