I am not getting spark on this 5hp, took off the flywheel and it is an old point coil. I cleaned and readjusted the points to .020 and it fired but would not run. I checked the spark again and no spark. I have not been able to find a replacement for this or can I just replace the points and condensor or is there a newer type coil that would work on this motor Model HS50-67175C It is on a snowblower.
