K5BEAST
have an ancient Troy built rototiller that has had a 5hp briggs engine, with the pulsajet carb, put on it somewhere along the way. I'm having issues keeping it running. It'll start great the first time and runs for 3, maybe 4, minutes and then dies. After that it is a **** to start. Seems like it is getting way too much fuel. I've been through the carb and tank. New diaphragm/ pump, new governor spring. I've cleaned the jets & passageways. Everything is clean. Triple checked the linkages. New fuel. I've tried adjusting the mixture screw in and out. Removed and cleaned behind it. I just don't understand why it's getting so much fuel and then just dies. It's a manual choke and it works as it should.
Hoping some of you gurus on here can enlighten me.....
