5hp has spark, brand new carb, gets fuel won't fire.
Frosted_Frogger
  • / 5hp has spark, brand new carb, gets fuel won't fire.
So i have a 5hp briggs and stratton on a tiller, i recently did a valve job, replaced the head gasket, put on a brand new carburetor, replaced the flywheel key, adjusted the coil gap, new spark plug, new air filter, changed the oil. I got it finished and re-mounted on the tiller, first pull and it started up and ran great except for a high pitch squealing coming from the pull start clutch. So i removed the front cover and the pull start clutch and fine sanded the shaft and wire brushed inside where the shaft goes into the clutch. Re-assembled everything and now it wont start. It acts like it isn't getting spark, yet when i connect a spark tester it is sparking fine. I am at a loss for the cause since it started on one pull prior to cleaning the pull start clutch, and in cleaning that i didn't even touch any other component.
Check the flywheel key.
EngineMan
Check to see if you have any dirt from the cleaning on the magnets and the poles of the coil, which can give a bad spark.
