I wasn't arguing with you about which line was as I seen your posted image, how close everything is. Just trying figured why it is leaking too as the next 445 that comes may have the same problem which is my luck.Yes sir it’s the line on the left (looking from clutch side) so it’s the feed line, I cleaned and dried everything well and hit the primer button and fuel starts coming from around where the feed line goes into the tank
I’m gonna stop by the husqie dealer and get another line. The one I had was Husqie but I’ve had it for about a yearI wasn't arguing with you about which line was as I seen your posted image, how close everything is. Just trying figured why it is leaking too as the next 445 that comes may have the same problem which is my luck.
I know where the leak is, just don’t know why.
I thought it was a Honda 455 Rancher ATV because you didn’t specify Husqvarna 455 Rancher chainsaw. My bad.Chainsaws don’t usually have a petcock
I realize there is no Honda 455cc engine. I thought maybe he meant 450cc, and made a mistake, like I did. Mistakes happen in life when you try.There is no Honda FourTrax 455 Rancher but there is a 420 Rancher. Now there is Honda FourTrax 450 Foreman. But yet there is no 455cc engine.
Either way this is posted under Husqvarna so we are to assume the poster know where to post the question; unless, it is obvious its is not the right OEM. Skimming things can get you in trouble. It is like taking something apart thinking you know how it goes back together to just realize you don't a week later.
