theelboxer
- Jul 18, 2011
- 2
- 2
I have a 3 hp briggs and Straton. Hadn't been cranked in 8 years. Finally got it to turn over for 5 seconds. I did this for about 15 tries and sprayed out the carb with cleaner. Must have washed into cylinder and stuck the rings, I now have no compression. I have the plug hole filled with carb cleaner and the oil drain open. Hope to fill up with carb cleaner tomorrow and see if it will break loose. Any other suggestions? Hope some one can help me out if I put new pistons and rings in. Thanks
