37 Hp Briggs Vangaurd Blew up
Valve head.....or seat.
Very possible - in which case the pieces got between the head and piston. That has the same effect including a damaged rod. The point is there is no happy ending here with a loose wire or dirt in the carb. Engine comes apart and if any pieces hit the cylinders, cam ect, they are toast too.
