PTmowerMech
- Apr 16, 2018
- 432
- 3,310
From the looks of this. Seems the flywheel key tried to come out the top. In doing so, broke part of it, and bent the rest of it. Also broke a big chunk of the fly wheel cone.
There's still a good piece of the key that I used to see of the keyway had spread any. And it did.
Example: when you sick a good fly wheel key into a keyway, there's very little wiggle room. Stick it in the top of the crank now, and there's about double the wiggle.
Thus on a customers, and I'm scared of putting another key in it, with it as loose as it is.
Looking for advise. Is the crank junk? Can I put some foil in it to tighten it up?
