Jim johnson
- Jun 30, 2017
- 1
Hello I have a John Deere 314 with a 14 hp kohler in it.all it wants to do is run at a idel, then shot off.If you give it any throttle at all it will shot off.I put new point,s in it,set at 20 new carb tried to adjust,put new fuel pump in it still the same .pull the choke out spit,s gas out the carb.wont run in less choke is off throttle is at it,s lowest point.pulled plug it,s dry.can some one shed some light please help thank you.
