3 year old Briggs and Stratton engine keeps spitting oil thru breather tube
akbryant
  • / 3 year old Briggs and Stratton engine keeps spitting oil thru breather tube
My 3 year old Briggs and Stratton series 625 engine keeps spitting oil thru breather tube and out thru air filter. I have twice replaced the breather reed and tube and it has happened before again. What could be causing it?
Scrubcadet10
Moderator
Staff member
Check your oil level, if overfull. smell for gasoline in the oil.
PTmowerMech
Did you try hollering at it? If that don't work then you may have to resort to threatening or even a good swift kick to the tires. he he he he he he
