Berniebac
- Apr 8, 2012
- 25
- 180
I have a Briggs 3.5 HP, Mod. 92902; Type 5211-01; Code 83012505. I have posted about itin another thread where I was asking about the coil gap. I have a new problem that I wanted to ask about.
I put a carb kit in it and a new air filter. After these installations I had it running perfect and mowed my yard at home with it. That was about an hour of steady mowing. I then took the mower to my cottage and tried to start it there and it would not start. I adjusted the idle screw again, and eventually got it running and mowed for about 45 minutes with it. I shut it off, and went backto start it after about 20 mins and it would not run. It would start but only idle very low and then shut down after about 30 secs. I tried to adjust it again but could not get it running smooth.
The only thing I noticed was some oil laying around the carb from when I had oiled the air filter. Thinking I had over oiled the air filter, I took the filter out and took some oil out of it by squeezing it in some paper towels. Still no go after removing some of the oil.
Any thoughts why it would be so difficult to start after having run so perfectly? What should I do to get it running again.
