22 horse Briggs & Stratton Poulan PRO will only start with help of a starter Fluid
Freedom
  • / 22 horse Briggs & Stratton Poulan PRO will only start with help of a starter Fluid
Thank you all very much for the answers. I learn a lot here. as someone said the problem is in the choke. I wanted to attacha video but i can't, is possible to send a video?
Auto Doc's
You need to provide us with the engine model and type number information that is stamped into the rocker cover on the engine.
Techs don't like to play guesses off of minimal information.
Should be either a 40N877-0015-G1, 44N677-0015-G1 or 44R677-0024-G1. IPLs 2008-2016 claiming it has 40N677-0015-G1 but Briggs Power Portal says no such animal. And IPL for the 2012-2013 has the 44R677-0024-G1. I leaning toward the 44N677-0015-G1.
But as said we the info off the rocker cover.
Freedom
Thanks The choke doesn't move at all when I move the lever up. The cable does move, and also the wheel at the right but the choke does not move up and down
my motor is:
model44R677
type0032G1
Code150116YG
Any suggestions?
Thanks!
F
Auto Doc's
Was the throttle cable takes off of this at some point?
IF this don't move [rotate].
But the inner extends and retracts then the cable clamp is probably missing or loose.
Auto Doc's
Removed the air cleaner and backing to see the actual choke plate. You may have to pull the entire upper fan shroud off. The linkage rod that operated the choke may have popped out of the clip at the bottom or top.
Take a couple of pictures from about a foot away when you get it apart.
Freedom
thanks!
