2016 Z-Force L 54
dirtfan1
Went to fire up my Z-force L54 and it would not turn over. Had it out last week to do spring maintenance on it and it started fine. Battery has plenty of juice to turn it over but it does nothing when you turn the key. I can take a pair of pliers or channel locks and jump the solenoid and it will start. Any and all help is appreciated. I did check fuse and it is not blown.
thanks in advance
When my tank would do that it was a bent hand brake control arm. It wouldn't engage the safety switch
