jason.samford
- May 7, 2017
- 1
- 4
Afternoon everyone, I have a 2015 Husky LT4200, with the MTD Powermore 420cc engine P90 series engine. The problem I am having is that it will start fine, and will run great for a while, then it will act like its starving for fuel and die and wont restart again and stay running till it cools off. Sometimes if I immediately choke it, it will continue to run for maybe 30 additional seconds. its not a definitive time like 10 minutes that it will run, most of the time its under 5 minutes other times it may run for 30 or more minutes before it dies. I did a little research and found that sometimes the anti fire solenoid will fail, so I replaced that, didn't help. I replaced the fuel filter every spring, but replaced it again for good measure, no difference. I ordered a new carb w/a new solenoid, and that didn't help. It has a very good strong spark, when its cold, and right after it dies. I checked and reset the valve lash per MTD specs .005 for intake and .007 for exhaust, no difference. I replaced the fuel cap, no change. I replaced the fuel lines, no change. Today I reset the air gap on the coil to MTD specs .020 on the magnets, no chance. I have ran out of ideas or things that I can think of to check, does anyone have any experience with this or know what I can do, other than pouring a gallon of gas on it and striking a match!
