Yes,
The deck height adjuster needs to be set so there is little to no weight on it.
Slip some 2 x 4's under the deck then adjust the height pedal so the lifting arms seem loose.
Use 2 x 4's hat are twice as long as the deck so you can slide the deck out sideways once the pins have been removed.
