2010 compact diesel pump belt issues
BigBear
I’m looking for some help on what is causing the belt to have so much slack in it and the adjuster is maxed out. It has a new belt from dealer(aftermarket part not OE bad boy)
BigBear
this is a picture of it
Scrubcadet10
Moderator
Staff member
belts can be put in wrong sleeves, (different dimensions) or sometimes just plain wrong in the length. even if it does come from the dealer.
What is the model of your mower?
MParr
Do you still have the old belt? If so, measure it and compare to the new one.
@Scrubcadet10 is correct.
BigBear
Old belt got eaten up when pump pulley came off.
MParr
Now we are getting somewhere. If the wrong pulley and belt were installed that could be your problem. Could you give us your model number and serial number?
BigBear
This is what I can find
Is it possible that the dealer gave you the pump belt for the mower with the 72 inch deck and not the pump belt for the mower with the 60 inch deck. About 2 inch difference in length and the 72 is listed first in the parts manual.
