2010 1/2 Grasshopper 226v hydraulic Oil reservoir grommets
LeGear1!
  • / 2010 1/2 Grasshopper 226v hydraulic Oil reservoir grommets
Is there any where the sealing grommets for the oil lines into the bottom of the reservoir can be purchased or is it necessary to replace the everything as a unit? The reservoir is in good condition, but the grommets need replacing.
Thanks for anyone's help,
WL McCabe
Looks like a grommet used by Toro/Wheelhorse tractors. You’ll have to remove one of the grmmets and measure its size. Do a goggle search for “toro fuel tank grommet” and you should be able to find the size you need.
LeGear1!
I appreciate your response and will follow up on the info.
Thanks,
WL McCabe
LeGear1!
Thanks,
WL McCabe
LeGear1!
Thanks,
WL McCabe
Toro/Wheelhorse grommets worked perfect.
Thanks
