2010 1/2 226V Grasshopper inline hydraulic strainer
LeGear1!
I removed the hydraulic strainer before realizing it had a flow arrow. Strainer is in line between reservoir and pumps, I think that the flow would be from the pumps to the reservoir, because the hydraulic filter is in the other line from the reservoir. Am I correct?
Thanks for your help,
WL McCabe
LeGear1!
After requesting info on the proper installation of the inline strainer, I started cleaning the parts for reassembly. While cleaning the oil filter housing I found a directional arrow on the top of the housing which gave the flow direction for the hydraulic system. It flows from the reservoir to the strainer, to the pumps, to the filter, and back to the reservoir. I appreciate your response.
WL McCabe
Well I was going suggest just testing the system to which the flow but I see you lucked out finding another flow arrow.
LeGear1!
Thanks for taking time to reply.
WL McCabe
