2008 John Deere Ztrak 737 no start
MikeC68
When I turn key on I hear a click but when I continue to turn the key completely to crank it does nothing no sound at all..
Any help would be greatly appreciated. Do not wont to just throw parts at it and do not have shop manual for it. Was thinking it may would be starter relay or solenoid.. Would not even know which relay is which without manual...Thanks in advance
Make sure the pto button is pressed down. You won't believe how many times that happens. Click could also be a relay due to a safety switch not being activated when required for starting. Jack position of direction levers to make sure they are all the way out and make sure the parking brake is on if it has one.
Thanks checked all safety switches and PTO is down
Should have a Kawasaki FH661V-AS04 (-R) engine. It will have a solenoid shift starter. Also has a fuel solenoid which would click anytime the ignition switch is on.
Thanks that looks like my set up except for the number 2 switch do not have that
