I was working on my 2007 John Deere Z425 this week and really screwed up. I had the machine in free roll and went to tighten the bypass valve rods and turned the one on the right the wrong way. I didn't recognize the mistake until the rod was about to come off in my hand. I reversed course and tightened the rod but that side no longer works properly. I'm trying to bleed any air from the hydraulics...jacking the mower up, loosening the bypass valves, starting the mower, press control lever forward then backward several times. When I push or pull the control lever(s) the wheels do turn but very weak. The right side does not pull enough to move the machine forward or reverse. This is the first time Ive ever had any issues with the drive mechanism. Any ideas on what this might be and how to correct it?
Thanks
Bryan
Thanks
Bryan
