s10sleeper
I recently bout a 2005 Poulan tractor with a 17.5 hp B&S. i thought it may have been valve lash preventing it from kicking past TDC, adjusted that, which the exhaust was way off. Charged the battery and changed out the oil. still no luck, it hits TDC and stops. When Checking voltage at the starter it drops from 12.5 down to 5v. No luck even with a jump start. I got the correct manual in today and it looks as though I will have to tear into it to check compression release. does anyone have an idea?
