VegetiveSteam
There is one down below the voltage regulator and one in the same place on the other side also. You probably will have to use a wrench. I don't believe you'll be able to get a ratchet and socket in there.
To do the annual "mouse nest eviction" that will cook an air cooled engine if not removed?What is the purpose of pulling the blower housing?
As in cleaning the cooling fins on these air cooled engines.......... Amen to that.To do the annual "mouse nest eviction" that will cook an air cooled engine if not removed?
Your engine.I often blow out the engine with compressed air through the mowing season and it's always worked for me.
Wow--no kidding? Would you happen to have a link to these kits?kohler makes a kit you can buy that has the templates to cut your blower housing with metal covers so you can just take the cover off and you don't have to take the blower housing off.
