ArmyAviator
- May 3, 2013
- 4
- 18
I sent this Rob, the Honda expert; thought I'd see if any Hustler owners might have had this issue:
Back on 26 NOV I had starting issues; new spark plugs seemed to solve that and she ran better than ever. Fast forward to about 2 weeks ago; she started but just didn't sound right...like the RPM wasn't as smooth; not rough per se...just odd. When engaging the blade, not enough power. Pulled plugs and found that that screw on cap that snaps into the sparkplug wire cap was very loose on one of them; solved the problem. It was running just fine 7 days ago. I just went to crank it and nothing but turning over. I pull the plugs, smells flooded, but no spark on either of them. I dried the plugs, made sure everything was tight on the plug...still no spark on either.
Thoughts? The engine is a GXV20 serial number: GJAD-2007687
How do you check spark on a coil? I am pretty fair mechanically; but not much exp w/ small engines.
Thank you.
--Bryant
Thank you.
--Bryant
