Grassbandit
- May 20, 2012
- 151
You cannot make a new slot anywhere in the flywheel, if that's what your above statement means. Timing is critical for 2-strokes to run properly. Even slightly moving the flywheel from it's original mating spot on the crankshaft will advance or ****** timing.
If this flywheel slot is truly gone, a replacement flywheel is the only solution.
In that case, I wont be able to save this trimmer.
Gonna just keep it as a parts donor unless I find a flywheel by some stroke of luck.
![DSC_0113[1].jpg DSC_0113[1].jpg](https://www.lawnmowerforum.com/data/attachments/15/15726-83934c3bb7c91042784b29fadc2efd17.jpg?hash=g5NMO7fJEE)
![DSC_0115[1].jpg DSC_0115[1].jpg](https://www.lawnmowerforum.com/data/attachments/15/15733-d12468ed201104570256b2ea9bdd96db.jpg?hash=0SRo7SARBF)
![DSC_0117[1].jpg DSC_0117[1].jpg](https://www.lawnmowerforum.com/data/attachments/15/15742-b6ed542dc9e802c9266c7add6a94ec8c.jpg?hash=tu1ULcnoAs)
