2-stroke fuel/oil mix in the old days.
Auto Doc's
Community Leader
Does anyone remember the (old) days before canned "pre-mixed" boutique fuels for 2-stroke equipment?
I worked in a small engine shop back in the late 70's and the rule was to keep life simple and get the job done. Mixing 2-stroke fuel was not a "rocket science project". There were no canned pre-mixed fuels back then that I was ever aware of. We kept one jug mixed for weed eater and chainsaws and the another for Lawn Boy 2-stroke mowers.
I also recall many cold mornings cutting cords of wood for winter and summers cutting roadside weed stalks for local ranch owners. I mixed my fuel as I used it, not in bulk to keep for "next time".
Typically, in the shop all we would do is mix a couple of oil bottle cap fulls of 10W-30 into a gallon of gasoline. When we ran the engine, we would simply watch for a little light (very faint) blue smoke.
When it came to my own SS30 Green Machine straight shaft cutter with a saw blade, I would fill the fuel tank and add about a half cap full of oil and then shake the machine for a minute to mix the fuel in the tank.
Times were simpler back then as long as I paid attention to how much oil I mixed in the gasoline. No smoke, not enough oil.... too much smoke meant too much oil in the mix. I made adjustments as I went along. It only took a few drops of more or less of oil in the mix to get the desired results.
Sounds too simple but it was meant to be. Now advertisers have people buying cans of pre-mixed canned fuels for some crazy prices and that stuff does not keep forever on a shelf in a sealed steel can.
On a side note: I never straight gassed and burnt up a motor cylinder and piston. I also never had to pull mufflers and burn them out with a torch due to excess oil coking/carbon buildup. (Ive had to do that on quite a number of canned pre-mix fuel machines.)
In recent years I have had many customer machines come in with "canned fuel disease" that were hard to start or not run as they got warmed up good.
Actually the old days was 1/2 pint of 30w non-detergent motor oil to a gallon of gas, for a 16:1 mix.
And you still fried cylinders. I replaced numerous Homelite cylinders when I was cutting firewood for the family. With the synthetics I don't see many ruined cylinders. And I still mix my shop's own fuel although I use those pre-measured multi mix oil packs now.
Anyone else remember when Saabs were 2 strokes? We had a neighbor with one. He carried a box in the trunk with small containers of Saab two stroke oil. Each container had the correct amount of oil for a full tank. We were all happy when that smoke screen deployment vehicle got traded in on a new Peugeot. Yup, he was a unique individual.
The Saab "bug foggers"
The problem with this scenario is he literally kept adding more oil to the mix when the fuel tank was not fully empty. Over a period of time his fuel mix got "oil heavy". Mix ratio went out the window.
the mixes were 16:1, 24:1, and 50:1 as I recall, depending on the engineering, mixed with non-ethanol leaded fuel. You'd do the math in your head, or use the chart on the bottle.
Based on school grade scores these days, one almost wonders if we weren't smarter because of the lead in the fuel. Ever watch those kids today try to figure out what to do when the total is $12.35 and they get handed a $20 dollar bill, two $1 dollar bills, and 35 cents? They freeze like a deer in the headlights.
